TIME TO REBUILD (currently 8,250 views) |
Posted on: June 4th, 2019, 18:49:29 |
Some really good progress there Simon! (Must pull my finger out on mine - ho hum). Liking the centre console. |
Reply: 30 - 51 |
Philip_Davenport |
Posted on: June 6th, 2019, 13:59:06 |
Simon -- did you get the Lexan windows? Can you share pics? Im thinking of fixed front windows with slider kits in. Ive got two soft top cars (MR2 & Spitfire) for summer, will so use the Marcos more in cooler months - especially in the snow -wicked ..
IMM is mid-August, so maybe 9 weeks of DVLA sh1te if you are taking the Marcos.. Id have no chance. Engine has not run in 30+ years .. |
Owner since March 2019 of SWD 588G Chassis: 7213 | Last modified June 6th, 2019, 14:00:14 by Philip_Davenport |
Reply: 31 - 51 |
Simon_Pike |
Posted on: June 6th, 2019, 21:44:28 |
Yes I did get them,but unfortunately they dont fit as the templates used were for a marcos cars mk4 which have smaller windows. Mines a dh fibreglass mk4 |
Last modified June 6th, 2019, 22:03:14 by Simon_Pike |
Reply: 32 - 51 |
Philip_Davenport |
Posted on: June 7th, 2019, 07:51:33 |
Sorry to hear that. A pain in butt ! So what do you do next about them? |
Reply: 33 - 51 |
Simon_Pike |
Posted on: June 7th, 2019, 08:41:03 |
Quoted from Philip_Davenport, posted June 7th, 2019, 07:51:33 at here |
make a template from my remaining original window and get them remade,hopefully sell the other ones
Reply: 34 - 51 |
Simon_Pike |
thanks to craig smith for making the harness brace bar harness fitted another job done |
Reply: 35 - 51 |
Simon_Pike |
had a little play around fitting arches need to cover those wide wheels,not the best arches but they are the perfect width |
Reply: 36 - 51 |
Simon_Pike |
rear looks ok |
Reply: 37 - 51 |
Simon_Pike |
had to take the wiper motor apart and turn the cog 180 degrees, now the wiper blades stop on the passenger side not the drivers side |
Reply: 38 - 51 |
Simon_Pike |
managed to get the bonnet secured down,unfortunatly the previous owner had cut the lip off at the front. just need to sort the big hole out or stick a v8 in it with a holley carb out the bonnet |
Reply: 39 - 51 |
Simon_Pike |
been having a look around trying to find something to cover the massive bonnet hole. found a bonnet vent for a mitsubishi l200,i dont think it looks to bad,its only until i get a new bonnet |
Reply: 40 - 51 |
Simon_Pike |
pretty good |
Reply: 41 - 51 |
Simon_Pike |
Posted on: July 12th, 2019, 14:20:44 |
thinks havnt been going to good lately, I re-ordered a new drivers window in the new dimensions as the previous ones i ordered were the wrong size. Waited 5 weeks and they had sent me the same old dimension windows,so thats another long wait for replacements and now i found out the dvla never received my v5 after 6 weeks of waiting(yeh of course it was lost in the post) So now there will be no imm in the marcos for me |
Reply: 42 - 51 |
Simon_Pike |
Posted on: July 19th, 2019, 09:54:31
Ive been staying out of the garage for the last 3 weeks due to the problems with the dvla and a certain plastics company,just totaly took the wind out of my sails and put me right off the marcos. But i did venture into the garage last night and though i would have another go at making a door handle as i had one left after the last one melted. over the moon i actually managed it |
Reply: 43 - 51 |
Simon_Pike |
Posted on: July 19th, 2019, 09:55:10
top job |
Reply: 44 - 51 |
