Posted on: February 18th, 2017, 20:43:18
Polyester filler Spray filler for the first coat !!!
Last modified February 18th, 2017, 20:55:19 by Goff_Allen
Private Message Reply: 45 - 167
Posted on: February 18th, 2017, 20:44:22
on its side
Private Message Reply: 46 - 167
Posted on: February 18th, 2017, 20:46:19
Subframe mounts
Private Message Reply: 47 - 167
Posted on: February 18th, 2017, 20:49:35
mountings
Private Message Reply: 48 - 167
Posted on: February 18th, 2017, 20:51:08
mountings
Private Message Reply: 49 - 167
Posted on: February 18th, 2017, 20:51:42
mountings
Private Message Reply: 50 - 167
Posted on: February 18th, 2017, 20:53:52
inner wheel arch ready for glassing over as the fiber glass was not attached, just laid over gel coat and not ruffed up !!!!
Private Message Reply: 51 - 167
Posted on: February 26th, 2017, 21:23:53
More work on the body , Ruffed up the surface for a couple of layers of matting in the floor pans , Removed two rusty bits of flat bar that had been poorly glassed over in the rear seat pan area , Removed the rusty front floor subframe mountings and replaced with stainless steel , Also removed fibreglass as the mounting were way out and repositioned them using the front subframe as a jig ,
Private Message Reply: 52 - 167
Posted on: February 26th, 2017, 21:24:59
floor pans
Private Message Reply: 53 - 167
Posted on: February 26th, 2017, 21:27:48
floor mountings
Private Message Reply: 54 - 167
Posted on: February 26th, 2017, 21:29:20
rotten floor mounting
Private Message Reply: 55 - 167
Posted on: February 26th, 2017, 21:31:35
two layers of fibre glass ,
Private Message Reply: 56 - 167
Posted on: February 26th, 2017, 21:33:07
Fibre glass cut away for new mountings
Private Message Reply: 57 - 167
Posted on: February 26th, 2017, 21:34:15
Subframe as a jig for the floor mountings
Private Message Reply: 58 - 167
Posted on: February 26th, 2017, 21:35:22
New Stainless steel mountings ready to glass over.
Private Message Reply: 59 - 167
Powered by e-blah Platinum 7 Final © 2001-2004   -   June 16th, 2026, 17:56:35
Files opened: 140 | Files closed: 140
